Hi guys, I just installed the system a few hours ago and I’m still trying to get the Wi-Fi to work. I’m running it on a Dell Optiplex 3050 Mini, which has an M.2 Wi-Fi adapter installed. I tested the computer with Arch and Batocera for gaming, and the Wi-Fi worked fine on both systems, but when I try to activate the Wi-Fi through umbrel.local, I get the following message: “Wi-Fi is not supported on this device. This may be due to a missing or incompatible wireless adapter.” Has anyone else had a similar problem? I also tried to fix it via CMD, but some basic Linux commands didn’t even work. I also tried checking the hardware with “nmtui,” and the components appeared as missing.
