Hi, as anyone figured out how to install wifi adapter into new Umbrel 1.1?
thanks
No reply and No fix I think …
sudo apt-get --yes install firmware-brcm80211 && sudo reboot
sudo nmcli device wifi connect password
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
linux-headers-6.6.28+rpt-rpi-2712 : Depends: linux-image-6.6.28+rpt-rpi-2712 (= 1:6.6.28-1+rpt1) but it is not going to be installed or
linux-image-6.6.28+rpt-rpi-2712-unsigned (= 1:6.6.28-1+rpt1) but it is not installable
linux-headers-6.6.28+rpt-rpi-v8 : Depends: linux-image-6.6.28+rpt-rpi-v8 (= 1:6.6.28-1+rpt1) but it is not going to be installed or linux-image-6.6.28+rpt-rpi-v8-unsigned (= 1:6.6.28-1+rpt1) but it i s not installable
linux-image-rpi-2712 : Depends: linux-image-6.6.28+rpt-rpi-2712 (= 1:6.6.28-1+rpt1) but it is not going to be installed
linux-image-rpi-v8 : Depends: linux-image-6.6.28+rpt-rpi-v8 (= 1:6.6.28-1+rpt1) but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
umbrel@umbrel3:~$ apt --fix-broken install
umbrel@umbrel:~$ sudo apt --fix-broken install
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Correcting dependencies… Done
The following additional packages will be installed:
linux-image-6.6.28+rpt-rpi-2712 linux-image-6.6.28+rpt-rpi-v8
Suggested packages:
linux-doc-6.6 debian-kernel-handbook
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
14 not fully installed or removed.
Need to get 58.6 MB of archives.
After this operation, 65.7 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 Index of /debian bookworm/main arm64 linux-image-6.6.28+rpt-rpi-2712 arm64 1:6.6.28-1+rpt1 [29.3 MB]
Get:2 Index of /debian bookworm/main arm64 linux-image-6.6.28+rpt-rpi-v8 arm64 1:6.6.28-1+rpt1 [29.3 MB]
Fetched 58.6 MB in 7s (7915 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database … 102550 files and directories currently installed.)
Preparing to unpack …/linux-image-6.6.28+rpt-rpi-2712_1%3a6.6.28-1+rpt1_arm64.deb …
Unpacking linux-image-6.6.28+rpt-rpi-2712 (1:6.6.28-1+rpt1) …
dpkg: error processing archive /var/cache/apt/archives/linux-image-6.6.28+rpt-rpi-2712_1%3a6.6.28-1+rpt1_arm64.deb (–unpack):
unable to clean up mess surrounding ‘./boot/System.map-6.6.28+rpt-rpi-2712’ before installing another version: Read-only file system
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
/etc/kernel/postrm.d/zz-systemd-boot:
Couldn’t find EFI system partition. It is recommended to mount it to /boot or /efi.
Alternatively, use --esp-path= to specify path to mount point.
Preparing to unpack …/linux-image-6.6.28+rpt-rpi-v8_1%3a6.6.28-1+rpt1_arm64.deb …
Unpacking linux-image-6.6.28+rpt-rpi-v8 (1:6.6.28-1+rpt1) …
dpkg: error processing archive /var/cache/apt/archives/linux-image-6.6.28+rpt-rpi-v8_1%3a6.6.28-1+rpt1_arm64.deb (–unpack):
unable to clean up mess surrounding ‘./boot/System.map-6.6.28+rpt-rpi-v8’ before installing another version: Read-only file system
Errors were encountered while processing:
