Why dose my electrs allways restart automatically?
I have use docker image rm “the electrs image”, then type ./script/start, it download the electrs image again. But I use “docker ps” found that the electrs container status up time no more than 10 minutes.Is there something wrong? In the web dashboard my channels are all offline.
My OS is Ubuntu21.04 (GNU/Linux 5.11.0-1017-raspi aarch64), Umbrel version is 0.4.0(I don’t know why It can not update automatically).
Thank you,
Hugo
Do a manual update as described in this guide or just reflash the mSD card with latest version 0.4.2 of Umbrel. Your data is safe, on mSD card is just the OS and apps, user data is on the SSD.
My God! The bitcoin.conf has been replaced! I have added some nodes in the file, now, I lost them.
Thank you @DarthCoin , all the containers are working normally. But there is a sync problem. It is print “2021-09-18T23:57:20Z Potential stale tip detected, will try using extra outbound peer (last tip update: 26460 seconds ago)” all the time when I use command “tail -f bitcoin/debug.log”. It was OK before update, the block sync process was 100%, and now it is 99.93%. What should I do?
After I run the command sudo ./script/debug, the output below:
0.4.2
Mem: 3.8G 299M 2.7G 3.0M 777M 3.3G
Swap: 0B 0B 0B
total: 7.9%
system: 7.9%
tor: 0%
thunderhub: 0%
lnd: 0%
electrs: 0%
bitcoin: 0%
Memory monitor logs
2021-09-22 22:06:25 Memory monitor running!
2021-09-22 22:13:51 Memory monitor running!
2021-09-22 22:41:24 Warning memory usage at 91%
2021-09-22 22:43:24 Warning memory usage at 91%
2021-09-22 22:58:26 Warning memory usage at 92%
2021-09-22 23:03:27 Warning memory usage at 91%
1853 ? R 0:00 bash ./scripts/memory-monitor
1855 ? R 0:00 bash ./scripts/memory-monitor
2021-09-23 12:19:45 Memory monitor running!
/dev/mmcblk0p2 30G 6.4G 22G 23% /
/dev/sda1 916G 523G 348G 61% /mnt/umbrel
Karen logs
karen is running in /mnt/umbrel/events
Got signal:
karen is getting triggered!
Got signal:
./karen: line 68: /mnt/umbrel/events/triggers/: Is a directory
Got signal:
Got signal:
Got signal: backup
Deriving keys…
Creating backup…
Adding random padding…
1+0 records in
1+0 records out
997 bytes copied, 0.000391681 s, 2.5 MB/s
Creating encrypted tarball…
backup/
backup/channel.backup
backup/.padding
Uploading backup…
0 0 0 0 0 0 0 0 --:–:-- 0:01:59 --:–:-- 0
curl: (97) Can’t complete SOCKS5 connection to pvf3ozmmfl.execute-api.us-east-1.amazonaws.com. (6)
====== Backup failed =======
Got signal:
Got signal:
Got signal:
Got signal:
Docker containers
NAMES STATUS
Bitcoin Core logs
Attaching to
LND logs
Attaching to
Tor logs
Attaching to
App logs
thunderhub
Attaching to
==== Result ====
Please copy the entire output of this script and paste it in the Umbrel Telegram group (https://t.me/getumbrel) so we can help you with your problem.
It’s recommended to upload the output somewhere and share a link to it. Run this script with ‘–upload’ to automatically generate a link to share.
Now who can help me to fix the problem why my lightning channels are all offline?
