What is..."Support the LN network"
I get it, but I don’t quite get it. So please let’s get practical here…
What is the minimum I should be opening channels with? How many channels should I have open? What are some good to open channels? Should I be messaging nodes first? What’s the protocol? Is looping out the a best practice?
Is balanced the best state to be in? Or is unbalanced better because I could spend more if I had more outbound? If I wanted to route more, would having more unbalanced inbound be better?
How much should I expect to make routing (yield)? How often should I see routing taken place via my channels?
Real world advice is greatly appreciated.
I am new here, will answer questions as best I can from my limited experience
Here is a good place to start https://mobile.twitter.com/ErinEMalone/status/1416901431181807617
2 Million Sats in a channel seems to be a consensus minimum
Seems to be more about the quality than the quantity. Going to depend on how many sats you want to put into the system.
Open with well-connected nodes and you’ll get more routing, but you’ll need some inbound liquidity too.
The best success I’ve had so far was coordinating with 2 other nodes to setup a triangular loop. A to B, B to C, C to A.
Not sure what this is referring to. The protocol for contacting other people about channels? The Lightning Protocol?
I have not been successful with looping yet and it seems expensive.
I think it will depend on the channel. Can get expensive to keep everything balanced all the time. If you have Some inbound and outbound liquidity, then you can get more advanced with channel management.
Yes, maybe? I think I’ll start looking at specific channels once I have more setup and doing more routing, to see what is being used and what is not being used.
Not a lot, at least at this time. Routing fees are tallied in millisatoshis (1/1,000th of a satoshi). I’ve made 2 full satoshis today with 4 open channels. Maybe this will increase as the network gains more traction, and better to learn about it now and have channels open so you can manage it if traffic gets heavier.
I’ve had a few payments routed through today. Took a few days before anything really happened. Setting up the triangle route seems to have helped.
