Web Access broken after upgrade
Hi, yesterday I blindly let the latest OS upgrade run (think it might have been 1.3) and now I cannot access Unbrel via the web page … I CAN access it via SSH.
This site can’t be reached
192.XXX.XXX.XXX refused to connect.
Any clues?
I’ve done the obvious reboot etc…
Cheers
Did you set a static ip for your umbrel?
Can you connect the device to some screen and keyboard? And if so, are you able to ping other devices in your home network?
No, I didn’t have a static set as I knew the IP. I could SSH to it and I could ping both other on-net devices and externally.
I say ‘could’ as I gave up and re-installed - world order has been restored but is was defiantly the OS upgrade to 1.3 that bricked it.
-A
Scan the subnet, for some reason it resets network settings, most likely has a new IP. This happened to me.
In case it helps. I had a similar problem a few days ago, trying to update to v1.3. I reported it on the forum’s discord channel but got no response. In the end, I ended up solving it myself.
Copy/paste from what I posted on discord.
What I can deduce from my experience is that there is something in the v1.3 installer that conflicts when upgrading from the previous version, causing the entire upgrade process to not be completed. Doing a clean install does not seem to cause conflicts.
Another important fact is that what prevented the Rpi4 from having access to the internet, even though I did a clean install of v1.3 more than 20 times, was my ISP’s router. Incredibly, the router had created a rule blocking the Rpi4’s mac and preventing it from connecting to the internet.
And I say “Incredibly” because I have never configured any rule on my ISP’s router. It is a router that I cannot change due to the configuration that my ISP uses and I only use it as a gateway without using any other service.
Anyway, and after consulting the router logs, said rule was created on the same day and time that the Rpi4 update to v1.3 failed.
I cannot say more about it. Only that I never created that rule and everything coincides in date and time. Somehow, the router blocked access.
I have a similar issue. After upgrading to v1.3 after roughly 10 Minutes after startup, I can’t login via SSH anymore and on the WebUI, almost none of the apps are responding anymore. With version v1.2 everything worked perfectly fine on my Raspberry Pi 5.
I don’t know what to do. I would like to downgrade to v1.2. Does anybody know how to accomplish that?
Kind Regards
Paddy
