Is there a way to view my Bitcoin node’s peers on Umbrel? I could do it on my Windows laptop by just running the Bitcoin Core software and viewing peers through the UI.
How can I see peers (both incoming and outgoing) on my Umbrel node?
If you’d like more specific information about your peers, you can use these steps:
bitcoin-cli getpeerinfoyou could install BTC RPC Explorer also.
OK, I was able to open up a terminal window, but bitcoin-cli doesn’t run from the default directory. Where is the program installed?
Ah ok, that’s working great, thanks!
http://umbrel.local:3002/peers (after installing the BTC RPC Explorer app)
