NerdQaxe++ and Umbrel-Home
Hello!
I’m looking to set up my NerdQAxe miner to connect directly to my Umbrel-Home node. What’s the best approach for configuring this for solo mining?"
thanks
Fav
Hello,
you have to install “Public Pool” or “Bassin” first (thats easy). After start the App you will see the IP and the port (Port 2018 for Public Pool and Port 3456 for Bassin).
Now you have to set the IP adress under “Pool Setting in Nerdqaxe++) and the port. click save and click restart
