Hi all,
I went from dead raspi (myNode) to Umbrel OS on Ubuntu 23. But my HDD didn’t die, so I can use my and only my (I trust nobody) downloaded blockchain to avoid syncing it from scratch for several days.
Here’s how I did it:
install bitcoin app, this will create folders and trigger syncing of blockchain, you need to stop it and shutdown Ubrel OS before copying:
sudo systemctl stop umbrel-startup
then:
sudo chown -R 1000:1000 /media/user/myNode/mynode/bitcoin/
- when you plug in your external HDD to Ubuntu, your path will look differently of course, so copy your whole path ( in explorer right click on folder > properties)
- this command will change your ownership rights from old HDD, so you can copy them to Ubuntu later
Now in your explorer go to your old HDD with blockchain > select folders “blocks”, “chainstate” and “indexes”, right click > copy > go to your Ubrel bitcoin location > paste > it will ask your to overwrite some already existing files > confirm all
That’s it, start your Umbrel OS and login to your bitcoin app, syncing will continue where it stopped (when my raspi died). All will take around 1 hour (SSD to SSD, but half TB of data!):
sudo systemctl start umbrel-startup
Bonus (replace “user” with your user name)
location to find blockchain on myNode:
location to find blockchain on Umbrel:
/home/user/umbrel/app-data/bitcoin/data/bitcoin/
