Update OS via command line?
Is there any harm to the OS install or security risk (especially for those of us running a Bitcoin / Lightning node) to using the command lines below for the purpose of updating packages on Umbrel?
sudo apt update
sudo apt upgrade -y
Also, would it be safe to install raspi-config to make it easier via a text interface to make changes to the parameters without having to know Linux commands?
