Update Apps or How we can do manually
Is there any way to update the apps manually? I need to update one urgently. @lukechilds can you help us?
Hey @Dax
Yes, you can manually update an app by modifying its docker-compose.yml.
Just SSH into your Umbrel, go to the app folder (under /umbrel/app-data/<app-name>), and edit the docker-compose.yml file to use the latest image or tag. For example:
image: someuser/appname:latest
Then restart the app. After saving the file, just restart the app from the Umbrel interface. Keep in mind: manual changes might get overwritten during future app updates.
Which app are you trying to update?
It’s the BTC pay server but it adds SHA256.
Simply change to:
btcpayserver/btcpayserver:2.1.5@sha256:54e5f24db058bbcf4450888265977355bb794c40909e8aeacc6d3c03137c9bab
Thank you very much. Could you please write down the process for obtaining the SHA and have it recorded in case other people need to make these updates?
You can find the SHA on Docker Hub under the image tag Just click on the tag and the SHA256 digest will be shown there. :flexed_biceps:
https://hub.docker.com/layers/btcpayserver/btcpayserver/2.1.5/images/sha256-e3946c1610a41b0bbe597b80e3a33f7d19f80e14c616a67e38615211352cf1be
Many people in the community are grateful to you
