So I been digging into Umbrel’s source code looking where they disabled portable storage support. Found it.
SSH to your Umbrel and type:
sudo nano /opt/umbreld/source/modules/is-umbrel-home.ts
Change this:
import fse from 'fs-extra'
import systeminfo from 'systeminformation'
export default async function isUmbrelHome() {
// This file exists in old versions of amd64 Umbrel OS builds due to the Docker build system.
// It confuses the systeminfo library and makes it return the model as 'Docker Container'.
await fse.remove('/.dockerenv')
const {manufacturer, model} = await systeminfo.system()
return manufacturer === 'Umbrel, Inc.' && model === 'Umbrel Home'
to:
return true
And there you go…
