Where will umbrel put the btc blockchain?
Good day! I have just downloaded UmbrelOS and installed on a laptop.
During the OS install I had the ethernet cable and usb stick plugged into the laptop’s 2 available usb ports.
After install, when I restarted, I took out the USB hard drive, and put ina 1 TB external hard drive.
I then installed Bitcoin Core, and I see it is now downloading the btc blockchain.
Question: There is not enough space on the laptop hard drive for the blockchain, however there is enough space on the external hard drive.
Will umbrel know that it “should” store the blockchain where it has space, on the external hard drive?
Thanks!
