Unable to install software
Hello,
I tried to install some software from the app store but after reaching 99% it stays there for a while and then dissapears (the icon from the dektop). Is there a way to to see a log of the installation procedure in order to get some insight of the reason it fails?
Thank you
Yes.
Umbrel → Settings → Troubleshoot → umbrelOS
This will show the log in reverse time order … look to see what error the Install App is getting to debug the problem.
Thank you, will take a look and see what I can find!
