I try to recover my umbrel, but I am unable to enter my 24 secret words. A spinning icon is displaying with no option to enter the seed words (see attached screenshot)
I had that issue also with v 4.10. Tried reinstall v 4.9 and 4.8 but didnt help. Had to do a clean install of v. 4.4 (with formating of SSD, loosing everything) to can get Umbrel working again.
my issue is occuring with a recent Umbrel 4.10 flash card and a clean formatted hard drive. I had to reflash et reformat because I was getting a lot of issues with latest versions of Umbrel. Now with a clean install I cannot recover my seed…I’m almost done with Umbrel, I’m getting too many issues…
Sure, v. 1.4.10 it is a disaster. I´m tring to find a version that is stable, maybe v 4.7, I will reinstall later to see.
The lesson is, if you have a working system, dont update. Last versions seems not tested, all full of problems.
We should ask developers a stable version, stop adding apps that we can’t run.
In the last version, en passant I noted a message saying something about “corrupted swap file” ???
Hi blukkub, sorry to hear about your issues - have you been able to generate any debug logs? If you can ssh in and run “tail -n200 ~/umbrel/logs/karen.log”, that will give us an idea if something is hanging on startup.
Hey everyone,
Thanks for your patience, we did find an issue with the 4.10 release for some new users, apologies for that. The solution is to format your SSD, and to reflash the v4.9 Umbrel release:
We will be releasing an update to fix the issue going forward, but thanks for providing logs and sorry again for the issues.
Getting the same issue with v4.9. Here is the debug log:
Got signal:
karen is getting triggered!
./karen: line 68: /home/umbrel/umbrel/events/triggers/: Is a directory
Got signal:
Got signal: backup
Deriving keys...
cat: /home/umbrel/umbrel/db/umbrel-seed/seed: No such file or directory
Missing derivation parameter, this is unsafe, exiting.
Got signal: backup
Deriving keys...
Got signal: backup
Deriving keys...
Got signal: backup
Deriving keys...
Got signal: backup
Deriving keys...
Got signal: backup
Deriving keys...
Got signal: backup
Deriving keys...
Got signal: backup
Deriving keys...
Got signal: backup
Deriving keys...
Got signal:
Got signal:
I could restore the seed with v4.8, but I had to reformat the hard drive.
