I am trying to open my first channel with this node and am getting this error in both Lightning node: “Unable to connect to peer, server is still in the process of starting”
Ride the lightning error when opening channel: “Server is still in the process of starting”
This is after my pi has been online for more than a week. So I have since shutdown, and restarted to see if that helps, but it does not.
I can open both the bitcoin node app and the lightning node app in umbrel and everything looks OK, I even have funds waiting in the lightning app to open channels with, but I am stuck.
I only have a few apps installed and want to use them all. Where did you see that it is out of memory in the logs? What is normal amount of apps for a raspberry pi 4?
I tried again this morning, still same error saying the server is starting, but its been up since yesterday
I just noticed it says free: 126M. But you have 8GB, that should be more than enough for the apps you’re running… I would try to remove apps like mempool and see if it helps just to rule out the memory issue.
I’ve got this exact same issue. Running latest OS 0.5.2 and LND 0.15.3-beta. Has been working well as a lightning node for many months, and now useless. Please can someone from Umbrel figure this out? Just get error in the logs:
2022-10-29 20:18:59.527 [ERR] RPCS: [/lnrpc.Lightning/ConnectPeer]: server is still in the process of starting
I also updated to the latest version of Umbrel, and I still have exactly the same issue. I cannot open any channels, error still says “Server is still in the process of starting”.
Hello! Did you solved it? I had to restore from the backup file and the transactions were not submitted due to this. I can’t recover my funds as all the channels are pending to be closed and I can’t add any peer due to this.
