I’m new to umbrel OS, first time installing it but I keep getting “Unable to compute new partition table Insufficient space can not add partition 6” What am I doing wrong?
Thanks,
Thanks,
hey, that error suggests umbrelOS can’t fit the partitions it needs onto the drive it’s trying to use, but it’s hard to tell why without a bit more info.
What are you installing on: a Raspberry Pi, a PC, or a VM? Also, how big is the drive you’re installing to, and which umbrelOS image did you download? If you’re using a USB stick for the installer, include its size separately from the destination drive.
A photo of the full error screen would help too. I’d hold off on deleting or resizing any partitions until it’s clear which drive it’s complaining about.
Same problem. Booting from 16Gb USB Drive (I tried two different USB drives), on baremetal PC
The problem was the 16Gb Pendrive. No issue using a 32Gb pendrive
I’m alao using a 16gb pen drive. I’ll try a 32gb later. Thanks.
