"Unable to check for update"
Since yesterday I am trying to update my Umbrel to 0.4.8. What could be the issue here?
Ok so the problem might be related to having Pi Hole running as my DNS server.
What is the best way to whitelist Umbrel ?
stop pihole, update, start pihole. Done
No, Pi-Hole is not the Problem for this particular error.
The HTTP 500 error code shows that the server is reachable but has a problem which was not handled.
My Umbrel currently shows the same error:
umbrel-manager
manager | Error getting available update: getaddrinfo EAI_AGAIN api.umbrel.com
manager | Unable to check for update
manager | /v1/system/get-update
manager | NodeError: Unable to check for update
manager | at Object.getAvailableUpdate (/app/logic/system.js:167:15)
manager | at processTicksAndRejections (internal/process/task_queues.js:97:5)
manager | ::ffff:10.21.21.2 - - [Sat, 21 Jan 2023 23:10:02 GMT] β€œGET /v1/system/get-update HTTP/1.0” 500 28 β€œ-” β€œMozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/16.2 Safari/605.1.15”
manager |
To me it looks like there is a problem with the umbrel server!
Or this is the normal behavior when no update was found. Not sure about this.
Hi, did you ever find the reason/ solution to this?
I know there is a 1.4 update atm but:
I am having a similar problem, check for update button fails, the web interface gives:
GET http://192.168.136.131/trpc/system.checkUpdate 500 (Internal Server Error)
umbrel log
Feb 28 17:44:53 umbrel umbreld[887]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how β†’ https://github.com/getumbrel/umbrel-apps#readme
Feb 28 17:45:13 umbrel umbreld[887]: [apprepository] Newer version of GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how β†’ https://github.com/getumbrel/umbrel-apps#readme available, updating
Feb 28 17:45:33 umbrel umbreld[887]: [appstore ] [error] Failed to update https://github.com/getumbrel/umbrel-apps.git: getaddrinfo EAI_AGAIN github.com
Feb 28 17:49:53 umbrel umbreld[887]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how β†’ https://github.com/getumbrel/umbrel-apps#readme
Feb 28 17:50:13 umbrel umbreld[887]: [apprepository] Newer version of GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how β†’ https://github.com/getumbrel/umbrel-apps#readme available, updating
Feb 28 17:50:33 umbrel umbreld[887]: [appstore ] [error] Failed to update https://github.com/getumbrel/umbrel-apps.git: getaddrinfo EAI_AGAIN github.com
Feb 28 17:51:04 umbrel NetworkManager[548]: [1740765064.4915] dhcp4 (ens33): state changed new lease, address=192.168.136.131
Feb 28 17:54:53 umbrel umbreld[887]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how β†’ https://github.com/getumbrel/umbrel-apps#readme
Feb 28 17:55:13 umbrel umbreld[887]: [apprepository] Newer version of GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how β†’ https://github.com/getumbrel/umbrel-apps#readme available, updating
Feb 28 17:55:33 umbrel umbreld[887]: [appstore ] [error] Failed to update https://github.com/getumbrel/umbrel-apps.git: getaddrinfo EAI_AGAIN github.com
Feb 28 17:58:08 umbrel umbreld[887]: [server ] [error] GET /system.checkUpdate fetch failed
Feb 28 17:59:53 umbrel umbreld[887]: [apprepository] Checking for update for GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how β†’ https://github.com/getumbrel/umbrel-apps#readme
Feb 28 18:00:13 umbrel umbreld[887]: [apprepository] Newer version of GitHub - getumbrel/umbrel-apps: The official app repository of the Umbrel App Store. Submit apps and updates here. Learn how β†’ https://github.com/getumbrel/umbrel-apps#readme available, updating
Feb 28 18:00:33 umbrel umbreld[887]: [appstore ] [error] Failed to update https://github.com/getumbrel/umbrel-apps.git: getaddrinfo EAI_AGAIN github.com
Feb 28 18:02:44 umbrel umbreld[887]: [server ] [error] GET /system.cpuTemperature Could not get CPU temperature
Feb 28 18:02:54 umbrel umbreld[887]: [server ] [error] GET /system.checkUpdate fetch failed
Feb 28 18:03:24 umbrel umbreld[887]: [server ] [error] GET /system.cpuTemperature Could not get CPU temperature
Feb 28 18:03:49 umbrel umbreld[887]: [server ] [error] GET /system.cpuTemperature Could not get CPU temperature
Feb 28 18:03:59 umbrel umbreld[887]: [server ] [error] GET /system.checkUpdate fetch failed
[EDIT:]
so I figured out its an dns problem, ping not pinging unless its ip, I am running umbrelos on a vm so I should be able to fix that, it just cant find github.com right now
