There’s this new update but I get an error when trying to update—does anyone have the same issue? Or have you been able to update without problems?
I’m on umbrelOS 1.5 Beta 2
Hey @enlil! ![]()
The update worked fine for me.
What error are you seeing exactly? If you can share the logs, we can take a closer look and try to help. ![]()
Hi I did the update from 1.5-2 to 1.5-3. It took a long time for it to be accessible again (1 hour). Can you try to see if waiting works, and if not, can you try to get the logs for it?
Hello again, sorry for my mistake. Although I have no idea about programming, I looked at the log file and understood what was happening to me. I was connecting the umbrel disk to a PC externally, I inserted it internally and it updated quickly and is working.
Greetings to all and thanks for the collaboration.
