Hello, I’m working on setting up Raspberry Pi using the Argon One V2 case. If I have Umbrel on the SD card, and the Blockchain on the SSD, how do I go about getting the fan to work. Have been looking for hours and can’t find much.
Same Here, have you fixed ?
No not fixed. I gave up on Umbrel, was issue after issue.
What alternative have you used ?
How you did?
I have been looking for an alternative but as yet nothing has come up to use. So I have given up on having a node for now. The previous version of Umbrel worked really well for me, but the new one was just problems.
