Hello, is it possible to upgrade umbrel pro to 32gb of ram? 16 is being used full
I’m sorry to be the bearer of bad news, but the 16GB RAM cannot be upgraded. The 16GB LPDDR5 RAM is soldered directly to the motherboard, and the Intel Core i3-N300 processor officially supports a maximum of 16GB memory (LPDDR5-4800).
I see, so it was badly projected because with apps like core, mempool and around 10 others all ram is being used and using half swap. Also the cpu is always around 30-40% of use. I removed the mempool app as it was using too much resources, still it’s using a lot of ram and cpu for a server:
