Umbrel.local doesnt work
Getting error:
This site can’t be reachedumbrel.local’s DNS address could not be found. Diagnosing the problem.
DNS_PROBE_STARTED
using my umbrel ip address works
How do i fix this?
I have restarted umbrel, it had no effect
I’m running pop_os and using chromium/vivaldi browser
You need to setup the local domain on the http conf file. @DarthCoin tenaciously wrote this guide that probably will be useful to you.
We highly recommend you using the amazing search functionality on this forum in the future, it provides a lot of insights :wink:
I should have mentioned I already went through his post and it didn’t help.
I have restarted the umbrel and it didnt help.
I have modified the etc/hosts file and it had no effect.
I can access it using the static ip though…
I’m stumped at this point
I figured it out, I had a type in my hosts file, thanks.
