Umbrel Cant install any app
I recently installed Umbrel on a new machine and started using it. The installation went smoothly, but I’m encountering an issue with installing any applications. When I click the install button, the progress shows 1%, then after a while, the installation is canceled. I’ve tried multiple applications and the result is the same.
Thank you.
umbrelos-amd64-usb-installer.iso installled on vmware
Device
VMware20,1
umbrelOS
umbrelOS 1.2.2
Local IP
I have exactly the same problem, I can’t install any app. But now I have another problem and lit I can’t access to umbrel.local on any device of the network idk
Instead of using umbrel.local, try accessing your Umbrel node using its local IP address. Does this work?
Thanks, but don’t work, I posted that problem in a new topic
