I just want to thank you folks who put this together and made it so painless to install on a pi5.
I actually had to go through the (clear) instructions 2x, as the first time I made the assumption that it couldn’t be that easy and started installing the old way…Re-read the instructions and can’t believe how simple you people made it.
Thank you thank you thank you.
