Os: Ubuntu 20.04
Reading package lists… Done
Building dependency tree
Reading state information… Done
libffi-dev is already the newest version (3.3-4).
python3-pip is already the newest version (20.0.2-5ubuntu1.8).
0 upgraded, 0 newly installed, 0 to remove and 250 not upgraded.
Requirement already satisfied: pip in ./miniconda/lib/python3.10/site-packages (23.0.1)
WARNING: Running pip as the ‘root’ user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
File “/usr/lib/python3.8/runpy.py”, line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File “/usr/lib/python3.8/runpy.py”, line 87, in _run_code
exec(code, run_globals)
File “/usr/lib/python3/dist-packages/pip/main.py”, line 16, in
from pip._internal.cli.main import main as _main # isort:skip # noqa
File “/usr/lib/python3/dist-packages/pip/_internal/cli/main.py”, line 10, in
from pip._internal.cli.autocompletion import autocomplete
File “/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py”, line 9, in
from pip._internal.cli.main_parser import create_main_parser
File “/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py”, line 7, in
from pip._internal.cli import cmdoptions
File “/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py”, line 24, in
from pip._internal.exceptions import CommandError
File “/usr/lib/python3/dist-packages/pip/_internal/exceptions.py”, line 10, in
from pip._vendor.six import iteritems
File “/usr/lib/python3/dist-packages/pip/_vendor/init.py”, line 65, in
vendored(“cachecontrol”)
File “/usr/lib/python3/dist-packages/pip/_vendor/init.py”, line 36, in vendored
import(modulename, globals(), locals(), level=0)
File “”, line 991, in _find_and_load
File “”, line 975, in _find_and_load_unlocked
File “”, line 655, in _load_unlocked
File “”, line 618, in _load_backward_compatible
File “”, line 259, in load_module
File “/usr/share/python-wheels/CacheControl-0.12.6-py2.py3-none-any.whl/cachecontrol/init.py”, line 9, in
File “/usr/share/python-wheels/CacheControl-0.12.6-py2.py3-none-any.whl/cachecontrol/wrapper.py”, line 1, in
File “/usr/share/python-wheels/CacheControl-0.12.6-py2.py3-none-any.whl/cachecontrol/adapter.py”, line 5, in
File “/usr/share/python-wheels/requests-2.22.0-py2.py3-none-any.whl/requests/init.py”, line 95, in
File “/usr/share/python-wheels/urllib3-1.25.8-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py”, line 46, in
File “/usr/lib/python3/dist-packages/OpenSSL/init.py”, line 8, in
from OpenSSL import crypto, SSL
File “/usr/lib/python3/dist-packages/OpenSSL/crypto.py”, line 1553, in
class X509StoreFlags(object):
File “/usr/lib/python3/dist-packages/OpenSSL/crypto.py”, line 1573, in X509StoreFlags
CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
AttributeError: module ‘lib’ has no attribute ‘X509_V_FLAG_CB_ISSUER_CHECK’
