Warning message while installing Umbrel on Raspberry OS
Hello everybody! Newbie here :smiley: I need help with a trouble that I’ve faced while installing Umbrel on my Raspberry Pi4 model B using Raspbian as OS. The following warning message displayed after couple minutes the installation begun. I typed “curl -L https://umbrel.sh | bash” in order to start the installation as suggested on their site.
“WARNING: The scripts pip, pip3 and pip3.9 are installed in ‘/home/lukedex/.local/bin’ which is not on PATH. Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.”
What do I need to do with these files? And what type of scripts are they in the first place? Thank you in advance for any help provided!
