Touch, Datei configured nicht gefunden
I don’t know what I exactly did that created this error, but now when I try to start umbrel I get:
Creating tor … done
Stopping tor … done
Removing tor … done
Configuring permissions…
touch: ‘/home/user/umbrel/…/statuses/configured’ kann nicht berührt werden: Datei oder Verzeichnis nicht gefunden
What to do ?
Thanks
P.S.: What kind of permission does the “umbrel”-folder need ?
I put this into the start-script:
echo ${BASH_SOURCE[0]}
echo $(dirname $(readlink -f "${BASH_SOURCE[0]}"))
echo $(dirname $(readlink -f "${BASH_SOURCE[0]}"))/..
./scripts/start
/home/user/umbrel/scripts
/home/user/umbrel/scripts/…
ok, managed to solve the problem…
After
sudo ./scripts/update/update --repo getumbrel/umbrel#v0.4.10
all the wrong configuration-setttings where resetted, and I managed to install 0.4.10.
Next problem: After clicking on “recover” with the 24 words nothing happened, endless waiting…
So I did:
sudo ./scripts/update/update --repo getumbrel/umbrel#v0.4.9
Now I was able to recover from my 24 words.
Now I will update through web-interface to 0.4.10 again
Hope this helps, if someone has similar problems
