Tor does not connect anymore
I run a umbrel home behind my router internal IP static x…x.x.71. I used to connect to it via tor.
Does not connect anymore: error 0xF0. I turned off TOR from control panel. I then rebooted my umbrel. I then re-enabled tor from the control panel.
The onion string is still the same, yet it does not connect neither from the local lan , nor from a remote wan.
