Hi all - has anybody had any success using Immich with Tailscale? I’ve pointed it back to my Tailscale IP for my node + the correct port and the phone app always states unable to connect. Any thoughts?
Have you found the solution for this?
Hopefully this thread here helps out- also I would recommend heading to your tailscale admin console and trying the tailscale IP as well as ‘umbrel.local’. Make sure tailscale is working on your phone too, you can check from any browser.
