Hi there, I’m running an Umbrel node, since around 6 months and it was running fine, since the last update, the space takes by the system increase undefinitively. I reinstalled it 2 weeks agoo and the same things hapend.
thanks for the help
System total - (Electrs & dbase + Bitcoin & dbase + mempool space) = System space (20ish GB)
That looks right. Maybe I’m looking at it wrong. How much space do you have left on the drive and how big is it?
Because the bitcoin chain is constantly growing
thanks for the interrest,
look at the 2 screen, “system” take more space than bitcoin node, I had more apps install for 6 months without any problem, “system” was taking less space I don’t remember exactly how much but I think it was less than 200 GB.
I reinstall my umbrel node from zero 2 weeks agoo because of this problem, bitcoin node was sync in only 2 days and didn’t grow up since. I saw system growing up by around 100 GB per day.
I have this problem since the last Umbrel update, I think it’s more link to the backup feature, wich have a big space optimisation problem too,
does it correct itself after reboot.
I believe ive seen some people report a bug that shows usage when its not there
yes, same thing after reboot
im just curious have you went looking in the cli ?
sorry for misunderstanding the issue.
I know ive read this problem either in here or on reddit recently. Ill see if i can find it
im sure youve dug deeeper into that data dir then?
im still looking all ive found so far are out of control logs..
go back one and look again
