Syncthing will not install. It stays as INSTALLING and then goes back to INSTALL. Error log shows the following - this happens also after fresh restart of the system:
Installing ‘syncthing’ from: https://github.com/getumbrel/umbrel-apps.git
Setting up data dir for app syncthing…
sending incremental file list
sent 146 bytes received 13 bytes 318.00 bytes/sec
total size is 1,684 speedup is 10.59
Pulling images for app syncthing…
Pulling server …
Pulling app_proxy …
Pulling server … pulling from syncthing/syncthing
Pulling app_proxy … pulling from getumbrel/app-proxy
Pulling server … digest: sha256:57699adea5bae30edd…
Pulling server … status: image is up to date for s…
Pulling server … done
Pulling app_proxy … digest: sha256:a2e3e0ddfcf84838bf…
Pulling app_proxy … status: image is up to date for g…
Pulling app_proxy … done
Starting app syncthing…
Starting syncthing_server_1 …
Starting syncthing_app_proxy_1 …
Host is already in use by another container
Starting syncthing_server_1 … error
ERROR: for syncthing_server_1 Cannot start service server: driver failed programming external connectivity on endpoint syncthing_server_1 (615e7f40e58b3fe66f3899760ee6853d62ea70ae3dae163fa17ce22cb67caa0e): Error starting userland proxy: listen tcp4 0.0.0.0:22000: bind: address already in use
Starting syncthing_app_proxy_1 … error
ERROR: for syncthing_app_proxy_1 Cannot start service app_proxy: driver failed programming external connectivity on endpoint syncthing_app_proxy_1 (c88a7906a33a018d108662d17bc9713a6f631040c40ae1006cb6adbb6fab5416): Error starting userland proxy: listen tcp4 0.0.0.0:8384: bind: address already in use
ERROR: for server Cannot start service server: driver failed programming external connectivity on endpoint syncthing_server_1 (615e7f40e58b3fe66f3899760ee6853d62ea70ae3dae163fa17ce22cb67caa0e): Error starting userland proxy: listen tcp4 0.0.0.0:22000: bind: address already in use
ERROR: for app_proxy Cannot start service app_proxy: driver failed programming external connectivity on endpoint syncthing_app_proxy_1 (c88a7906a33a018d108662d17bc9713a6f631040c40ae1006cb6adbb6fab5416): Error starting userland proxy: listen tcp4 0.0.0.0:8384: bind: address already in use
Got signal: change-password
karen is getting triggered!
This script must only be run on Umbrel OS
Got signal: debug
