Is there anyway to make use of op_return so that we can send bitcoin transactions with messages that will stay on the blockchain?
I think you can use RTL or Thunderhub app for that
I thought those apps were for lightning only?
So I’ve installed both apps, and i can see that you can send on-chain tx’s on both, but I can’t see anywhere to specify an op_return message into the blockchain
thanks for this, but i was hoping there was GUI rather than try my hand at the terminal. Don’t want to mess anything up and potentially lose funds.
another way could be with electrum wallet app
try also this, creating the tx here and then sign it and broadcasting it with electrum
https://coinb.in/#newTransaction
