Hi. My Bitcoin node stalled. I read that I need to login to the node and remove some file, via SSH. However, the password “moneyprintergobrrr” is no longer working. It worked when I first set up the pi but after plugging it into the router and running the Bitcoin Node for a day, the node stalled and I can no longer log in. Any advice?
I also read about installing the App: Ride the Lightning to reset my password. I installed it in Umbrel about 20 mins ago and that is not loading when I launch the app. Not sure if the two are connected or not… Again, it’s only been 20 mins.
Try your web login password instead.
