What happens when 1TB SSD will be full?
take a new one 2TB and make an image copy of the old one. I suggest to use Acronis clone disk image. You can boot with a special disk created by Acronis and is making a clone bit by bit.
Is the best way to move huge data as a node data, without losing properties and skip errors copying.
Has anyone actually tested this with success? I found that when I plug a new or same HD in, everything is formatted all over … I am not sure if this is something anyone has noticed.
Then there’s something you’re not doing correctly, but here’s a guide for those who have Windows PC: [GUIDE] Cloning or Migrating SSD/HDD (Windows)
