Hi, I seem to have trouble getting sphinx to work properly.
90% of the time, it says my node is disconnected. Every so often it will connect and work, but it is rare. It basically has the little yellow lightning bolt at the top right-most times, instead of a green one.
I have tried it using a device on the same network as my node, as well as one that is on a different network. Only the latter works, on occasion. It never works on my home network.
I have a raspi 4 4gb with a 1tb ssd. The node is connected through ethernet.
I’m using the android app running through orbot. I have tried the windows app which doesn’t work at all for me. I can’t even get that one to establish a connection.
Anyways, I’m not sure how to troubleshoot this. Any help is appreciated!
