(Solved) Questions before upgrading hardware
I’m going to upgrade from a Raspberry Pi 4 to a NUC. I’ve been looking around the forum but there are some aspects that are not entirely clear to me. I would appreciate your help. I’ll explain them below.
I’m planning to do a clean installation of Umbrelos on a NUC with 2 SSDs. One 120GB SSD for Umbrelos and the second 2TB SSD to store the blockchain and apps.
The idea will be to redirect the “app-data” folder of Umbrelos on the 120GB SSD to the 2TB SSD so that all the apps are stored there.
The questions are as follows.
1.- If a problem appears with the installation of Umbrelos on the 120Gb ssd, do I just have to reinstall the image as it is done by reflashing the sd on a raspberrypi and my apps will not be lost since they are on the second 2Tb ssd?.
2.- I assume that if the assumption of the previous point is correct, the only thing I would have to reconfigure would be the redirection of the “app-data” folder of Umbrelos on the 120Gb ssd to the 2Tb ssd where all the apps are stored. Is my approach correct?
I appreciate any help you can give me.
Thanks.
Well, so many days passed while this post was being authorized for publication that I have now resolved it myself.
I think the matter can be considered closed.
