Run the script to install Umbrel, and get to this part where it says:
============ CONFIGURING =============
=============== UMBREL ===============
Generating auth credentials
Generating Tor password
Unable to find image ‘getumbrel/tor:0.4.7.8@sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a’ locally
docker.io/getumbrel/tor@sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a: Pulling from getumbrel/tor
461246efe0a7: Pull complete
c8bc27c5e55c: Pull complete
472ce9feeded: Pull complete
Digest: sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a
Status: Image is up to date for getumbrel/tor@sha256:2ace83f22501f58857fa9b403009f595137fa2e7986c4fda79d82a8119072b6a
sed: can’t read ./templates/nginx.conf: No such file or directory
and then quits. I search and find this file “/umbrel/templates/nginx-sample.conf” but not a nginx.conf.
This should be pretty easy ![]()
