denny
December 15, 2024, 8:34pm
22
REMINDER!
@nmfretz @lukechilds @mayank @octolance - I kindly request that the Samourai Server app be updated as it has not been functioning for several weeks. A timely resolution would be greatly appreciated to restore its functionality.
opened 08:01AM - 09 Nov 24 UTC
**Description:**
I am encountering a recurring error with Samourai Server wh… en it attempts to interact with Bitcoin Core. The error log shows the following message repeatedly:
2024-11-03T22:15:46Z ERROR Bitcoind RPC : LatestBlock.onBlockHash()
{ code: -32600, message: 'jsonrpc field must be a string' }
See also here:
https://community.umbrel.com/t/samourai-broken-after-upgrade-bitcoin-core-to-28-0/19811
**Steps to Reproduce:**
Start Samourai Server and Bitcoin Core. Observe the error messages in the Samourai Server logs.
**Expected Behavior:**
Samourai Server should interact with Bitcoin Core without JSON-RPC field errors.
**Actual Behavior:**
The server logs an error indicating that the `jsonrpc` field must be a string, preventing normal operation.
**Troubleshooting Attempts:**
- Checked configuration files for JSON-RPC formatting issues.
- Ensured jsonrpc field is set to "2.0" in any relevant configurations.
- Restarted both Samourai Server and Bitcoin Core.
**Additional Information:**
This error may indicate an incompatibility between the versions of Samourai Server and Bitcoin Core, or a possible configuration issue with JSON-RPC fields.
denny
December 28, 2024, 1:46pm
24
Just 50 more times “up” and then they update.
samourai server is fixed. Thank you, whoever you are. I’ll be honest, I thought it will not be solved.
Rier26
January 20, 2026, 5:46pm
27
Hello everyone. Is samourai server going to be updated? It’s been several releases back. Or maybe could be a dojo port.
