RTL Umbrel (Update Service Settings Failed!) and empty Macaroon Data
Hello everyone, requesting for help. I’m getting this error in RTL
hoping any source that i can read or anything that helps i’ll be grateful
regards
P.D.
i’m brand new , sorry if i bother you guys if the answer is obvious
Node Config>Services>Boltz
partial log
ride-the-lightning_web_1 | [6/21/2024, 1:14:08 AM] INFO: Boltz => Getting List Swaps…
ride-the-lightning_web_1 | [6/21/2024, 1:14:08 AM] ERROR: Common => Boltz macaroon Error: ENOENT: no such file or directory, open ‘/boltz/.boltz-lnd/macaroons/admin.macaroon’
ride-the-lightning_web_1 | [6/21/2024, 1:14:08 AM] INFO: Common => Boltz Options.
ride-the-lightning_web_1 | [6/21/2024, 1:14:08 AM] ERROR: Boltz => List Swaps Error: {“name”:“StatusCodeError”,“statusCode”:500,“message”:“500 - {"code":2,"message":"empty macaroon data","details":}”,“error”:“500 - {"code":2,"message":"empty macaroon data","details":}”,“options”:{“url”:“https://ride-the-lightning_boltz_1:9003/v1/listswaps”,“rejectUnauthorized”:false,“json”:true,“headers”:{“Grpc-Metadata-macaroon”:“”},“simple”:true,“resolveWithFullResponse”:false,“transform2xxOnly”:false},“response”:{“statusCode”:500,“body”:{“code”:2,“message”:“empty macaroon data”,“details”:},“headers”:{“content-type”:“application/json”,“vary”:“Origin”,“date”:“Fri, 21 Jun 2024 01:14:08 GMT”,“content-length”:“57”,“connection”:“close”},“request”:{“uri”:{“protocol”:“https:”,“slashes”:true,“auth”:null,“host”:“ride-the-lightning_boltz_1:9003”,“port”:“9003”,“hostname”:“ride-the-lightning_boltz_1”,“hash”:null,“search”:null,“query”:null,“pathname”:“/v1/listswaps”,“path”:“/v1/listswaps”,“href”:“https://ride-the-lightning_boltz_1:9003/v1/listswaps”},“method”:“GET”,“headers”:{“Grpc-Metadata-macaroon”:“”,“accept”:“application/json”}}}}
ride-the-lightning_web_1 | [6/21/2024, 1:14:51 AM] INFO: RTLConf => Updating Service Settings…
ride-the-lightning_web_1 | [6/21/2024, 1:14:51 AM] ERROR: App => DEFUALT ERROR: Cannot set properties of undefined (setting ‘boltzMacaroonPath’)
ride-the-lightning_boltz_1 | 2024-06-21 00:37:51.149 [INFO ] Starting swap update listener
ride-the-lightning_boltz_1 | 2024-06-21 00:37:51.149 [INFO ] Recovering pending Swaps
ride-the-lightning_boltz_1 | 2024-06-21 00:37:51.149 [INFO ] Connecting to mempool websocket api: wss://liquid.network/api/v1/ws
ride-the-lightning_boltz_1 | 2024-06-21 00:37:51.150 [INFO ] Connected to LND block epoch stream
ride-the-lightning_boltz_1 | 2024-06-21 00:37:51.150 [INFO ] Starting RPC server on: 127.0.0.1:9002
ride-the-lightning_boltz_1 | 2024-06-21 00:37:51.150 [INFO ] Starting REST server on: 0.0.0.0:9003
ride-the-lightning_web_1 | [6/21/2024, 1:16:28 AM] INFO: RTLConf => Updating Service Settings…
ride-the-lightning_web_1 | [6/21/2024, 1:16:28 AM] ERROR: App => DEFUALT ERROR: Cannot set properties of undefined (setting ‘boltzMacaroonPath’)
Update(21/JUN/2024):
also when i open the tab services en BOLTZ promp me this
Any updates?
