RPi4b 2GB enough?
I am looking to run my own BTC node and PiHole (and possibly Lightning node as well). Just discovered the Embrel and looks promising - easy to use, with a great selection of apps.
Found a bargain RPI4b 2GB kit for sale (70 euros), but I am wondering - will that be enough to comfortably run Umbrel with BTC node and PiHole?
PS: I have an Unraid home-lab/server, but would prefer to run BTC node and PiHole on a different machine.
Thanks in advance!
nope … at least 4gb minimum but 8GB is good , you can get a pi400 4GB it’s cheap .
Thanks for your answer. pi400 is about 120 euros new, which could get a used Intel NUC with an i3. Will have to think about this some more.
if you are in EU check kubii you can get the pi400 for 78,84 €.
Thanks for the tip, they do have good prices!
