I just picked up a RPi 5 and swapped out my RPi 4 that was running Umbrel flawlessly. The Pi 4 had no issues running Bitcoin core, Electrs, Mempoo, Jam and Snowflake. I made sure Bitcoin core was up to date to v27.
As soon as the Pi 5 booted up, both Jam and Snowflake (Tor Relay) would not open, giving an unable to connect message. (It appears Jam has an issue with 1.1 and an issue has been filed).
After troubleshooting for quite some time, including switching ports on the docker container as per some community posts, I resorted to doing a fresh reinstall the Pi 5 image using BalenaEtcher and wiping my 2TB hard drive connected to the Pi. The first thing I did after initialization was install Snowflake and it gave me the same error. I switched the docker ports from 3800 to 3805 and to a number of other ports without luck.
I reinstalled core, electrs, and it’s syncing without issues.
The logs are always the same for Snowflake:
snowflake_app_proxy_1 | Error waiting for port: "The address 'snowflake_web_1' cannot be found"
snowflake_app_proxy_1 | Retrying...
The app itself does appear to be relaying traffic per the logs, but I believe the snowflake_web_1 is the frontend GUI that allows us to see the connection statuses.
Dialing into the Umbrel (using SSH), I was able to see that web was having issues starting:
$ sudo docker compose ls
NAME STATUS CONFIG FILES
bitcoin running(5) /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml,/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml,/home/umbrel/umbrel/app-data/bitcoin/docker-compose.yml
electrs running(4) /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml,/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml,/home/umbrel/umbrel/app-data/electrs/docker-compose.yml
snowflake restarting(1), running(2) /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.app_proxy.yml,/usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.common.yml,/home/umbrel/umbrel/app-data/snowflake/docker-compose.yml
umbrel running(2) /usr/local/lib/node_modules/umbreld/source/modules/apps/legacy-compat/docker-compose.yml
Checking the container logs, it also confirms it’s been restarting.
$ sudo docker container ls
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
c5c19a029e44 getumbrel/umbrel-bitcoin:v0.7.0 "docker-entrypoint.s…" About an hour ago Up About an hour 3006/tcp bitcoin_server_1
be59f130ac86 getumbrel/umbrel-electrs:v1.0.2 "docker-entrypoint.s…" About an hour ago Up About an hour 3006/tcp electrs_app_1
092dea50bdad lncm/bitcoind:v27.0 "bitcoind -port=8333…" About an hour ago Up About an hour 8080/tcp, 18332-18333/tcp, 18443-18444/tcp, 28332-28333/tcp, 0.0.0.0:8332-8333->8332-8333/tcp, :::8332-8333->8332-8333/tcp bitcoin_bitcoind_1
df6b4d4e1c24 purplei2p/i2pd:release-2.44.0 "/entrypoint.sh --sa…" About an hour ago Up About an hour 2827/tcp, 4444/tcp, 4447/tcp, 7070/tcp, 7650/tcp, 7654/tcp, 7656/tcp bitcoin_i2pd_daemon_1
6da43dc1d5dd getumbrel/app-proxy:1.0.0 "docker-entrypoint.s…" About an hour ago Up About an hour 0.0.0.0:2100->2100/tcp, :::2100->2100/tcp bitcoin_app_proxy_1
9fef348b3834 getumbrel/tor:0.4.7.8 "tor" About an hour ago Up About an hour bitcoin_tor_1
28256fed0df2 getumbrel/tor:0.4.7.8 "tor" About an hour ago Up About an hour electrs_tor_1
7f17e18a0c60 getumbrel/electrs:v0.10.2 "electrs" About an hour ago Up About an hour 4224/tcp, 0.0.0.0:50001->50001/tcp, :::50001->50001/tcp electrs_electrs_1
fb49a9a66c39 getumbrel/app-proxy:1.0.0 "docker-entrypoint.s…" About an hour ago Up About an hour 0.0.0.0:2102->2102/tcp, :::2102->2102/tcp electrs_app_proxy_1
520aecba431c getumbrel/snowflake:v2.7.0 "/bin/proxy -log /da…" About an hour ago Up About an hour snowflake_proxy_1
7af9eee7f11a getumbrel/app-proxy:1.0.0 "docker-entrypoint.s…" About an hour ago Up About an hour 0.0.0.0:3800->3800/tcp, :::3800->3800/tcp snowflake_app_proxy_1
8d0547502cf7 getumbrel/gotty:v1.0.1 "gotty --port 3800 -…" About an hour ago Restarting (1) 1 second ago snowflake_web_1
9a20fb5d12e8 getumbrel/auth-server:1.0.5 "docker-entrypoint.s…" About an hour ago Up About an hour 0.0.0.0:2000->2000/tcp, :::2000->2000/tcp auth
13e3a4330952 getumbrel/tor:0.4.7.8 "tor" About an hour ago Up About an hour
The container logs point to a page size error:
$ sudo docker container logs 8d0547502cf7
<snip>
runtime: kernel page size (16384) is larger than runtime page size (4096)
I also filed an issue here directly in Github. If this is incorrect, please feel free to remove.
There are some posts online that help with setting a smaller page size, but I’m not the best with docker. Before I start messing around with the underlying system, does anyone have any ideas on how to fix this properly? Like I said, all my apps including core, eletrs, jam and snowflake worked without any issues on my RPi 4.
Thanks.
