Reinstall on Raspberry PI 4 model B
Hy everyone,
I have a problem with the sd-card (is dead) and i need to reinstall all from 0 (my btc node i have backed my channel) on a Raspberry PI 4 model B 8GB and i can`t find the archive to flash it, can anyone point me to a download link
Many Thanks
Be sure you aware of the issues and workarounds with newer version of umbrelOS before you decide what version you want to install!
Thank you, but i have try it many times 1.7.2/umbrelos-pi4.img.zip also try 1.7.1/umbrelos-pi4.img.zip and i get the same error its says no bootable partition… (and the flash was ok with no error) wen i flash umbrel-os-v0.5.4 its working without any problem.
Any pointers what the issues are? Any problems specific to Raspberry Pi 4 Model B?
I’m trying to revive one on which I was previously running Umbrel pre 1.0. Now when I flash to SD Card it boots OK, but when trying to boot via USB drive I just get a black screen.
Edit: nevermind, I notice the wiki says “Booting from NVMe or USB is not supported on Raspberry Pi 4.” Guess I’ll no longer be running UmbrelOS.
Solution is to flash 1.3 and after that you update in umbrel to 1.7.2
