suklee
1
Started getting this error out of the blue:
Corruption: block checksum mismatch: stored = 987848892, computed = 4231933485, type = 1 in /data/db/bitcoin/859839.sst offset 28075246 size 1984" }', src/db.rs:346:14
Is there a way to force reindex of only electrs, without uninstalling it? I’m using an Umbrel Home.
Vish1
2
I would like to suggest few steps
- Stop the electrs service and
- Create a backup for existing /data/db/bitcoin/
- Then create a new directory and start the electrs service.
Hope it helps !
suklee
3
Just want to update, after updating Electrs to 0.10.6 today the issue fixed itself
