Still having issues to update to any version higher than 0.4.3-build-1c80170. As a part me learning and investigating the issue I ran the command to reindex (sudo systemctl stop umbrel-startup && sudo rm -rf ~/umbrel/electrs/!(electrs.toml) && sudo systemctl start umbrel-startup) which gives me the following error below. Does that perhaps mean that the file blk00540.dat is corrupt? Shouldn’t the reindexing fix such error? How can that get fixed? Any help would be much appreciated.
BTW: Reindexing always stops at the same file(blk00540.dat) and starts over and over again from the beginning.
electrs | TRACE - indexed “/data/.bitcoin/blocks/blk00538.dat”: 0 rows
electrs | DEBUG - no more blocks to index
electrs | TRACE - indexed “/data/.bitcoin/blocks/blk00539.dat”: 0 rows
electrs | TRACE - indexed “/data/.bitcoin/blocks/blk00540.dat”: 0 rows
electrs | thread ‘main’ panicked at ‘reader failed: Error(Msg(“failed to read “/data/.bitcoin/blocks/blk00541.dat””), State { next_error: Some(Os { code: 5, kind: Other, message: “Input/output error” }), backtrace: InternalBacktrace { backtrace: None } })’, src/libcore/result.rs:1188:5
electrs | note: run with RUST_BACKTRACE=1 environment variable to display a backtrace.
electrs | TRACE - closing DB at “/data/db/mainnet”
electrs | Config { log: StdErrLog { verbosity: Trace, quiet: false, show_level: true, timestamp: Off, modules: [], writer: “stderr”, color_choice: Never }, network_type: Bitcoin, db_path: “/data/db/mainnet”, daemon_dir: “/data/.bitcoin”, blocks_dir: “/data/.bitcoin/blocks”, daemon_rpc_addr: V4(10.21.21.8:8332), electrum_rpc_addr: V4(0.0.0.0:50001), monitoring_addr: V4(127.0.0.1:4224), jsonrpc_import: false, index_batch_size: 10, bulk_index_threads: 4, tx_cache_size: 10485760, txid_limit: 100, server_banner: “Umbrel v0.4.3”, blocktxids_cache_size: 10485760 }
electrs | DEBUG - Server listening on 127.0.0.1:4224
electrs | DEBUG - Running accept thread
electrs | INFO - NetworkInfo { version: 210100, subversion: “/Satoshi:0.21.1/”, relayfee: 0.00001 }
electrs | INFO - BlockchainInfo { chain: “main”, blocks: 710426, headers: 710426, verificationprogress: 0.9999989087659374, bestblockhash: “000000000000000000017019b6a0878917a9738f09c261fd97915b48ad785a8c”, pruned: false, initialblockdownload: false }
electrs | DEBUG - opening DB at “/data/db/mainnet”
electrs | TRACE - latest indexed blockhash: 0000000000000000000000000000000000000000000000000000000000000000
electrs | INFO - listing block files at “/data/.bitcoin/blocks/blk*.dat”
electrs | INFO - indexing 2812 blk*.dat files
electrs | DEBUG - found 415727 indexed blocks
electrs | TRACE - downloading 100000 block headers
