Hi, My Raspberry Pi stopped working. I doubt my SD card is at fault because I replaced it a few months ago.
I will install Umbrel OS on an x86 machine. My question is: Can I port my old channels to the new x86 machine?
BTW, I flashed the micro SD card with an older version of Umbrel. Will this affect the migration process?
Hey, I’ve done this before, I manually moved ~/umbrel/app-data/{app_name} to my x86 installation.
It worked fine I would be careful with lightning channels though, make sure you have the latest state, then copy them to the new machine and it should work.
I have the SSD still in tact. Will this work?
Just wondering if you are able to assist me via Telegram as I am very weak on terminal commands. I can pay you in Sats.
It should, I used this method to migrate from RPi to x86.
You can drop a message to the same ID on Telegram if you want.
