Public Pool stratum+tcp://umbrel.local:2018
Greetings, I’m new here. I have a question. Public Pool under UnbrelOS isn’t assigning me an IP address for the Stratum, just “umbrel.local”. I just started and also downloaded the new version of UnbrelOS 1.5. UmbrelOS has an IP assigned 192.168.X.XX, Router as DHCP.
P.S. I’m running it locally and just wanted to confirm that the Stratum address is correct. I noticed in some videos that the Stratum is shown as an IP address.
Thanks.
Thanks.
Hey @BrokenVoltage, welcome! :waving_hand:
That’s normal. Umbrel uses umbrel.local as its hostname on your local network. It resolves automatically to your Umbrel’s IP (like 192.168.x.xx), so you don’t need to enter the IP manually.
For your Stratum setup, just use:
Host: umbrel.local
Port: 2018
:backhand_index_pointing_right: Don’t include stratum+tcp:// or any other prefix, just umbrel.local and the port.
If your device doesn’t resolve umbrel.local, you can still use your Umbrel’s IP instead.
Make sure both devices are on the same LAN and your router’s DHCP keeps the IP stable (or set it static).
You’re good to go! :flexed_biceps:
