Problems connecting Samourai app with Dojo on Umbrel - API KEY ERROR!
Connecting my android with Samouria on Umbrel when I scan the QR Code I have this error "Unable to connect to Dojo: Please check your api key or your Dojo Status"
On the Dojo Maintenance Tool all looks fine (all ticks are green) and checking the Api key I have on the wallet is the same that the one that appear on Pairing on the DMT.
The problem is from Umbrel or from Samourai??
What can I do, any suggestions or help??
