Byzzyy
1
On Umbrel with umbrelOS 1.5, I installed both SearXNG and Perplexica from the App Store.
I added the SearXNG URL in the Perplexica / Search config section:
http://myIP:8182
Unfortunately, Perplexica does not receive search results.
Checking SearXNG setup from command line:
curl -X GET "http://myIP:8182/search?q=test&format=json"
returns the information:
Found. Redirecting to http://myIP:2000/?origin=host&app=searxng&path=%2Fsearch%3Fq%3Dtest%26format%3Djson
Any idea where this redirect 8182 to 2000 derives from, and how to avoid it?
chrip
2
When I used SearXNG previously (not on Umbrel but might be similar), I had to add the json format in the settings.yml.
