Hi…I was setting permissions for some folders while trying to make my Jellyfin work…don´t even remember which folders I used chmod on, but I guess it was data…anyways, didn´t work, I deleted Jelyfinn, and now my Umbrel starts ok, but I cannot access any app anymore… went to the terminal to try to set permissions all back to 777 (it´s my home network, I’m the only user) but I get this…
umbrel@umbrel:~$ sudo su
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
All other chmods I try I get an “operation not permitted” error…
How can I solve this? This is a bare metal install…Umbrel 1.2.1
Thanks!
