Not being able to use umbrel home when nìconnected to wifi repeaters
now, my home is made of 5 floors so it makes sense to have 1 repeater for one floor each but when i connect try to connect to umbrel.wind3.hub (my router adds .wind3.hub at the end) via wifi i cannot access my umbrel! When i connect via ethernet it works fine. How do i fix this?
I would suggest using the IP Address that is assigned by your router instead of the umbrel.local address. Umbrel Setting page will tell you the Local IP Assigned. For best results, have your router assign a Permanent IP address to your UmbrelOS’s MAC Address.
okay, thanks…
