Hi
I am currently running 0.5.1.
I get the Umbrel 0.5.3 is now available popup, but after running the installation process and restarting, I am still on v. 0.5.1?
What could be the issue here?
Hi
You could try manually updating with the procedure from the guide
To manually update your node using SSH access.
Make a channels backup. Go to Umbrel dashboard - Lightning and on the right top side, 3 dots, save backup on your local PC.
A. For Rasp Pi users:
Enter using SSH into your Umbrel node, then run:
cd ~/umbrel && sudo ./scripts/update/update--repo getumbrel/umbrel#v0.4.8
Replace v0.4.8 with the version you want to update to.
If the update was stuck in update, run this before the above command:
sudo rm statuses/update-in-progress
sudo rm statuses/update-status.json
Restart your node if is done OK:
sudo reboot
B. For normal Linux OS users:
sudo ./scripts/stop
Save your lnd.conf file if you edited (add color, name or specific features to your node). How to edit lnd.conf in Umbrel. More details about what you can add to a lnd.conf file here . After version 0.4.0 this file is not overwritten anymore with a default one, but just in case, make a backup.
Update system:
sudo apt update && sudo apt upgrade -y
Restart system
Update Umbrel (replace version with the latest release):
cd ~/umbrel && sudo ./scripts/update/update --repo getumbrel/umbrel#v0.4.8
Replace lnd.conf file with the one you save it before update (After version 0.4.0 this file is not overwritten anymore with a default one)
Start Umbrel:
sudo ./scripts/start
